Slave address and send setpoint for ThermoNeslab bath
Hey everyone,
     I downloaded the rte-17 drivers online,im using rs-485 connection so i had to modify some of the driver to work.I got it to work on slave address 1 but i try a different address it doesn work,i notice the light blinks on the unit but no feedback,also im trying to send commands for setpoint to the unit and it wouldnt work,thanks
(3,494 Views)
I just took a look at the Neslab RTE-17 library.  It was created using a old version of NI-VISA, you may need to replace some of the VI's with the current VISA VI's if using a modern version.
Other than that, I found the manual here.
Ben
Certified LabVIEW Associate Developer
Certified TestStand Developer
(3,470 Views)
Hey Ben thanks for the response,
     I replaced the vi's with new Visa's like i said address 01 works good as far as getting internal temp,but if i put the unit to a second address, and try the vi it doesnt work
(3,466 Views)
I have attached the vi i made for the device,maybe something wrong?thanks for your help
(3,452 Views)
I can't see anything wrong with how you are programming with VISA.  Perhaps another user has some experience using this particular instrument.
Ben
(3,442 Views)
