Slow Power Ramp Up
I have a high power voltage supply.  I need to slowly ramp up the voltage of the power supply, say 20 V per second, up to 1000 V.
I can control the power of the supply manually. For example I can set the power supply to be 100 V run the program, then 120 V run the program, etc. Is there a way to have the program do this automatically?
Attached please see my code.
Thanks for the help.
Respectfully,
Andre
Message 1 of 9
(7,603 Views)
What power supply?  Do you have drivers for it?  A simple FOR loop or a state machine could easily do this.
Message 2 of 9
(7,599 Views)
I have a SRS PS 350.
Can I take my entire program and then do a small for loop with a let's say half a second delay? How would I incrementally increase the power to the supply?
Thanks for your help.
Message 3 of 9
(7,590 Views)
Use a shift register to hold your set voltage and increment it with each iteration.
Message 4 of 9
(7,581 Views)
Message 5 of 9
(7,578 Views)
Or use the Ramp function to create an array of step values and wire that through a for loop.
Message 6 of 9
(7,575 Views)
Could you please provide me with a bit more information, where do I find the ramp function? and do I simply replace my manual control with a ramp function?
I apologize LabVIEW is not my strong area.
Help is greatly appreciated.
Message 7 of 9
(7,566 Views)
Use the search button on the function palette.
You should look at some of the free tutorials. Pay attention to the auto-indexing feature of a for loop.
Message 8 of 9
(7,559 Views)
Message 9 of 9
(7,553 Views)
