Solar Cell Characterization setup
Hello, for a research project I am using Labview, a Keithley 2601A source meter, and a gpib-usb-hs for my set up right now. My issue I am having is that the gpib is ready but not active and when I look for the device on visa it pops up but I am not sure how the data from the source meter to my computer for the Labview vi. I am not used to this system, this is my first time using any ni software and labview, so any help is appreciated, thank you.
(1,007 Views)
The 2601 (programming) manual should answer your questions. (RTFM always helps 😉 )
Your can look for a LabVIEW driver for this unit. (Quite shure you can find it) help/Find Instrument Drivers
After installing, you usually find examples for the basics (help/Find examples..)
Greetings from Germany
Henrik
LV since v3.1
(976 Views)
