Hi
I appreciate the time you took to answer my questions.
Masih
ā06-04-2011 07:09 AM
Hi
I connect my tunable laser to my PC and my spectrum analyzer is connected to my tunable laser. Is it possible to write program while in labview while I want to get data from my spectrum analyzer and simeltenously control my tunable laser?
Masih
ā06-04-2011 08:11 AM
GPIB control is essentially sequential. Write to A, then write to B, etc.
ā06-04-2011 10:17 AM
Hi
I have one GPIB card and I want to contorl two optical device( optical spectrum analyzer, tunable laser) , is it possible?
if yes, could you send two me an example?
thanks
Masih
ā06-04-2011 11:28 AM
Of course it's possible. I would suggest you search for a GPIB tutorial before starting.
In LabVIEW, you would most often be using VISA commands and you merely have to provide a different VISA Resource Name for each instrument - i.e. GPIB0::3::INSTR AND GPIB::4:INSTR where 3 and 4 are the GPIB addresses. You don't even have to type them into the control. You use the control's pull-down menu to select from a list. The list is created when you do a scan for instruments in MAX. This should all be explained in the Getting Started document that comes with the NI GPIB controller.
ā06-05-2011 04:31 AM
Hi
Masih
ā06-05-2011 05:11 AM
I am trying to find some related tutorial about VISA function but I can not find. I do not know how to read data from other instrument such as spectrum analyzer.Could you help me?
Masih
ā06-05-2011 02:51 PM
In your other post, I gave a link to the Instrument Driver Network. There is a link there to a getting started with instrument control tutorial. Have you done that?
ā06-05-2011 03:10 PM
Hi
Could you send that link to me again, please?
Masih
ā06-05-2011 05:27 PM
This is your other post. You could have simply clicked on your login name.
ā06-20-2011 11:45 AM
Hi
Now, I can connect my tunable laser to the labview and control it, also I can connect my spectrum analyzer to the labview and read the data from it. My question here is, how I can send data to the tunable laser and read data from spectrum analyzer simultaneously?
