Suggestion for Reliable IR/Positional Sensor compatible with USB 6212
I have a hollow cylinder(Inner diameter 1/3 inch) where there is a rubber piston goes up and down through the one end of the hollow cylinder. On the other end, I want to put a sensor, that will detect the current position of the rubber piston.
Personally I prefer sensors with Analog outputs, so that I can get data through NI USB 6212 DAQ. Can you suggest me a compact sensor that gives reliable data?
(982 Views)
Distance range?
Accuracy?
Drift?
Dynamics (how fast)?
Reliable ??? Time? , conditions (temp, humidity,....)?
CNY70??
or something like a µ-epsilon confocalDT IFS2403  😉
Greetings from Germany
Henrik
LV since v3.1
(940 Views)
Sorry I did not add the specifications.
Distance range: 0-8 inches
Accuracy: Error should be less than 1%
Dynamic: Maximum frequency 10Hz
Conditions: room temperature
I used reliable to highlight accuracy of the sensor. I prefer some sensors that has analog output.
(929 Views)
Checkout the sensors available at https://www.automationdirect.com/adc/shopping/catalog/sensors_-z-_encoders/photoelectric_sensors/dis...
This company has a good configurator tool - https://www.micro-epsilon.com/displacement-position-sensors/laser-sensor/konfigurator/
and ILD1420-200 seem to fit your requirements.
In general, distance sensors are going to be LASER based
Santhosh
Soliton Technologies
(923 Views)
