Home
Community
Discussion Forums
Most Active Hardware Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Switch case problem
Switch case problem
sujeep
Member
06-22-2007
06:58 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Hiii,
Help plz.
we i click on D button then the delay numeric control must be enabled
T button then threshold numeric control must be enabled
Q button to exit
and so on.
i have attached the program. plz explain me to complete it.
Thanks in advance.
LBProgram.vi 12 KB
0
Kudos
Message
1
of 2
(3,249 Views)
Reply
Re : Switch case problem
JB
Trusted Enthusiast
06-22-2007
07:38 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
The best method is to use an event structure. See attached example and post back if you need further help.
LBProgram-2_EVENT.vi 23 KB
0
Kudos
Message
2
of 2
(3,246 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
