This widget could not be displayed.
TNT4882 wrong data read from FIFO running test programm
I am new for GPIB and I start from test from "Using the TNT4882 in an 8051-Family Microcontroller-Based System". We use AT32UC3A microcontroller and I rewrite test in C. FIFOA and FIFOB test running without error. When programm test NFF and NEF interrupts I receive error. Debugging show that both interrupts work fine, there is error reading data from FIFOB (test programm request NFF interrupt and interrupt handler push 2 bytes to FIFOB. then test request NEF and handler read 2 bytes from FIFOB). Programm push 0x55 and 0xaa, hadler read 0xf2 0xaa. I try different things - nothing change, finally I push 3 bytes to FIFOB - dummy 0x50, then 0x55 and 0xaa. this time I read correct 2 bytes in handler - 0x55 and 0x55. Please note that just before interrupt test FIFOA and FIFOB was tested writing -reading with data range0-255 without error. There is a source code of the interrupt test (I leave original procedures descriptions from app note):
//* Module : INT_TST *//
//* Description : Performs Interrupt Test. *//
//* Reference : MCS51 & TNT4882 Application Notes. *//
unsigned char int_tst_4882(void)
unsigned char i;
    errorTNT=0;
    printString("waiting for NFF interrupt...", 50, 220, GREEN, (U8 *)&pfont[0]);
    tnt[(IMR3<<2)| BASE]=0x08;        //Write interrupt bit NFF to interrupt register
    //wait until it become 0
    do{i=tnt[(IMR3<<2)| BASE];}while((i&0x08)!=0);
    printString("waiting for NEF interrupt...", 50, 230, GREEN, (U8 *)&pfont[0]);
    tnt[(IMR3<<2)| BASE]=0x04;        //Write interrupt bit NEF to interrupt register
    do{i=tnt[(IMR3<<2)| BASE];}while((i&0x04)!=0);
    return(errorTNT);
//* Module : HANDLER *//
//* Parameters : NONE *//
//* Description : Interrupt Handler. This routine is entered when the *//
//* TNT chip asserts its interrupt signal. The interrupts*//
//* should be enabled for interrupts to occur. *//
//* The handler handles two cases of interrupts. These *//
//* cases are INPUT, and OUTPUT. *//
//interrupt.
//in this procedure we will handle interrupt from TNT4882
//X-Y coordinates of the touch panel
__attribute__((__interrupt__))
static void gpio_pb28_int(void)
unsigned char i,a;
    //printString("Interrupt active", 50, 210, GREEN, (U8 *)&pfont[0]);
    a=tnt[(ISR3<<2)| BASE];
    if ((i & a & 0x08)!=0x08)
        { //maybe NEF?
        if ((i & a & 0x04)!=0x04)
              errorTNT=1;
              goto intend;
        i=i & 0xFB;    //reset NFF flag and put it back
        tnt[(IMR3<<2)| BASE]=i;
        //read data from FIFOB
        a = tnt[(FIFOB<<2)| BASE];        //Read $55 from FIFOB
        i = tnt[(FIFOB<<2)| BASE];        //Read $AA from FIFOB
        if (a!=0x55 || i!=0xaa)
            errorTNT=1;
            goto intend;
    else    //NFF
        i = i & a & 0xF7;    //reset NFF flag and put it back
        tnt[(CMDR<<2) | BASE]=0x10; //Reset FIFOs
        //!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!/DUMMY WRITE FOR UNKNOW REASONS
        tnt[(FIFOB<<2)| BASE]=0x50;        //DUMMY WRITE FOR UNKNOW REASONS
        tnt[(FIFOB<<2)| BASE]=0x55;        //Write $55 to FIFOB
        tnt[(FIFOB<<2)| BASE]=0xaa;        //Write $AA to FIFOB
intend:
        gpio_clear_pin_interrupt_flag(GPIO_PIN_INT);   //Reset INT state of the input pin
May be someone can explain what and why happen - why I did not read original data and should write "dummy" byte?
Thank you very much in advance for  your help and support!
(3,534 Views)
(3,531 Views)
Thank you very much for your reply and note. I did not find answer to my question until now. May be you can give me more specific direction?
Thank you very much in advance for your answer!
(3,481 Views)
