TTI QL355TP Install Instructions
I have do a quick install instructions for QL355TP.
This tutorial is attached to this post.
 I'm Sorr, it's only in Spanish.
He creado una pequeña guía para instalar la QL355TP.
Esta guía esta adjunta a este mensaje.
Lo siento, sólo está disponible en Español.
(4,881 Views)
Accepted by zancos
Just like the first time you asked this question, I have no idea what you want. Do you need someone to translate the instructions into English?
(4,866 Views)
This is just the solution about how to install the unit in LabView.
I had a lot of problems, and now that Ihave solved it, I hav upload the instrucctions.
If somebody could translate it into english will be fantastic.
(4,737 Views)
