Tektronix DPO4054B Channel Query
Does anyone know of any command to query the channel number of a specified active measurement?
For example, when using cmd MEASUrement:MEAS<x>? This returns all measurement parameters for the specified active measurement <x>; but how to retrieve the scope channel for that measurement?
(3,669 Views)
Try using
DATa:SOUrce?
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(3,636 Views)
Accepted by Morben
Go read the Programmer's Manual.  You will find that the command you are looking for is
MEASUrement:MEAS<x>:SOURCE[1]?
or the shorthand
MEASU:MEAS<x>:SOURCE?
(3,632 Views)
Thanks, this worked and was implemented on my test.
(3,602 Views)
From Crossrulz tag line:
(3,597 Views)
