Tektronix TDS 220 Oscope not found by MAX using USB GPIB HS
Max 5.4 will not identify my Tk TDS 220 for any GPIB address I set it to.
THANKS for any help!
I've already tried everything from these links:
http://www.ni.com/download/ni-488.2-3.1.1/3786/en/
http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=289
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=047216EC20B66FABE0440003BA7CCD...
(5,024 Views)
Hi VISluth!
Is your instrument set to allow external control? You can find information about this in the instrument manual.
Also, while looking into the TDS 220, I found the following webpage which could suggest that you have defective hardware:
http://www.tek.com/service/safety/tds210-tds220
You could also check for IP between the instrument and your computer.
(4,990 Views)
I have the same (similar) problem.
Have you found a solution?
Eugen Wiebe
Bernstein AG
CLAD - Certified LabView Associate Developer
(3,800 Views)
Solved for me!
I had to use a GPIB cable (because the USB->GPUB Adapter from NI was too big and did not correct plug)
and I also installed TekVISA (but did not replace the NI Visa).
And now it works fine for me.
Also the both drivers for LabView are very good!
Many thanks to NI!
Eugen Wiebe
Bernstein AG
(3,786 Views)
