Tektronix TDS2024C usb issue
    I have a TDS2024C and connected to PC by usb.
    NI Max can detect the device, but when I tried to send command through VISA test panel,  it doesn't work.
    is there any suggestions?
Thanks!
Message 1 of 9
(6,586 Views)
What did you try and what did you expect to work.
Post a screenshot of the detected system if possible.
greetings from the Netherlands
Message 2 of 9
(6,564 Views)
Hi Here is the screen shot.
you can see the Ni Max detected the oscilloscope, but can't send commands to it.
Message 3 of 9
(6,563 Views)
Indeed MAX sees this but MAX only knows when USB is working correctly.
So without hardware to test I only can guess:
I see two USB connectors, I hope you connected to the back
And I see Signal express is on board shouldn't that be disconnected? Or external computer conected?
Message 4 of 9
(6,560 Views)
   Yes, usb is connected to the back of the scope.
    So is there any setting I need to do?
     When I connected the scope to a computer, I installed TekVISA, not sure if it is necessary or it cause the problem. And I restarted computer too. What else I can do to find the problem?
thanks!
Message 5 of 9
(6,557 Views)
Tek visa is probably fighting with max.
Please stay as close as possible to ni software.
Message 6 of 9
(6,552 Views)
Accepted by ForrestGan
For some of these instruments, it prefers the other selection in the Windows Control Panel for USB.  Select the USBTMC which is the USB Test & Measurement Class Device driver.  I have had to use this in the past for some Tektronix instruments.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
Message 7 of 9
(6,535 Views)
    the instrument was shown as USB Test & Measurement Class Device in the device manager.
    somehow after I disable and enable the device again, now everything works fine.
     I am still using the usb address shown in the NI Max.
Best
Message 8 of 9
(6,528 Views)
pls send your vi ..how you are communicating to ur instyrument using visa.. or post the snap shots step by step..
Message 9 of 9
(5,929 Views)
