Termination character finding problem
Great answer.
Please tell me that which I have to add 0XA, 10, /n????
Coming data is in acsii??????/
Message 31 of 36
(5,069 Views)
If you are using a C compiler, use "\n".  That is a special character in C to designate a new line.
Data coming from where?  You told us that the data from the instrument is binary.  You are making a special converter to change it to ASCII.  That is what you told us.  Is that information not correct?
Message 32 of 36
(5,063 Views)
yes my statment is correct.
Data that run seven segment display is in bits and I make a converter that convert bits that run 7-segment display to ASCII
Message 33 of 36
(5,058 Views)
Since your inability to append a termination character and even your inability to understand what a termination character is, is solely Ann issue with the firmware of your hardware, you need to take your questions elsewhere. There is no LabVIEW problem or NI hardware problem. Find a c forum for help in understanding how to write the firmware. Move on and mark the thread as solved.
Message 34 of 36
(5,048 Views)
Hellow I have one question after searching on website that
Using windows OS, we have to use both EOL and CR as termination character in Labview. that is \r\n
I am using windows 8.1 and want to add termination character in coming string. Either I have to add both of them or single linefeed will do work for termination caharcter.????
Message 35 of 36
(5,021 Views)
Windows doesn't matter in this case.  VISA only uses 1 character for the termination character.  Just use the Line Feed.
Message 36 of 36
(5,015 Views)
