The USB remote issue in 63600-2
Hi everybody,
Looking forward to receiving your advice.
I had problems with the 63600-2 when controlling it remotely using the USB interface.
While connecting the 63600-2 to my computer using the USB interface, I manually disconnect the USB cable but the RMT icon lights up then I connect the 63600-2 to the 2nd computer and I cannot remotely control the 63600-2 with your second computer.
I had to reboot the 63600-2 using the power button on the front to make sure the RMT icon was off, then use NI Max on the 2nd computer to restart the remote session, which I could then control from away from the 63600-2 of the 2nd computer. But now I bring the 63600-2 to the first computer and can't use this computer anymore. I have to restart my 1st computer.
I think when I manually unplug the USB cable, the communication session at  63600-2 and Computer is not released properly. So when reconnecting, the communication session cannot be re-established.
(1,306 Views)
I have no idea what the 63600-2 is but its firmware may be a little buggy and it doesn't automatically transfer from local to remote mode and back. So maybe you need to send it an explicit command to go back into local mode before disconnecting from it. And running the instrument drivers Close function (or at least the VISA Close function if there is no real instrument driver for your device) before trying to disconnect the device may help too.
If the device firmware is programmed properly it should automatically detect that it was disconnected from the computer and reset itself into a disconnected state, but that seems not to work for your device.
Rolf Kalbermatter  My Blog
(1,267 Views)
Thank you so much, Rolfk
63600-2 is Chroma electrical load. May I know the command of Close function? Because currently I have no idea about it.
(1,247 Views)
Can you share the user manual? I don't want to register to just download the manual.
https://www.chromausa.com/document-library/manuals-63600-series/
Santhosh
Soliton Technologies
(1,240 Views)
Thanks Santo,
This user manual is bigger than the maximum size. please use my drive: https://drive.google.com/file/d/1JvNfTgQ1ncT3AYYzyNZgyGdl4Q6kJfNU/view?usp=sharing
(1,230 Views)
Accepted by TaoHT
Well there are two. If you have an Instrument Driver, it usually contains a specific function called <Instrument Name>_Close or similar. That would be the function that should be called before you close the application or disconnect the device.
If you use directly VISA functions you would usually at least need to call VISA Close to make sure the port and any associated resources are properly released. Some devices also need some functions to be executed to properly set them back into a specific state but that is devices specific and has to be gotten from the according Programmer Reference Manual or Protocol Specification.
(1,210 Views)
Thank Rolfk,
I'm really appreciate your expertise. I need to check with my team, currently we had one way to avoid this problem so I have to back to R&D team to add the Visa close command in the script.
Thank
(1,161 Views)
