The VISTA software for the GPIB-USB-HS seems to be missing a driver
I downloaded the VISTA compatible software for the GPIB-USB-HS but the software seems to be missing a driver or something. How do I get this to work and recognize the attached GPIB cable?
(4,304 Views)
Hey George,
Try uninstalling the current driver. Then install this driver. This should then let you use the GPIB-USB-HS with Windows Vista.
Jason W
(4,282 Views)
I had this same issue, which your links did not resolve. I recently bought a Dell with Vista and I want to install my GPIB-USB-HS. I first had the issue with unsupported software, so i uninstalled everything, and used the removal tool. After installing the 488.2 v2.5, I plugged in my GPIB-USB-HS. Vista did not locate the driver, and because I do not have a disk, I pointed to C:\Program Files\National Instruments\NI-488.2. This did not provide Vista with the driver. Any ideas? Also, after using the removal tool, the old directories remain in the NI folder. thanks for any help! -B
(4,232 Views)
Hello Brad2thebone:
Have you tried removing the old directories? When Windows looks for the driver, does it always prompt you for the cd?
Roland A.
Check out VI Roadshow
(4,202 Views)
So I uninstalled all the NI software and removed the directories and I was able to install the GPIB-USB-HS driver. Now I have to setup labview... :|
(4,193 Views)
