To control shutter SC10
Hi!
We have thorlabs SC10 optical beam shutter and shutter controller. I was trying to control the shutter with LabView program.  I have attached the program vi.
What I understand after reading the manual (page 14-16) that the "ens?" will return "0" when the shutter is closed, and "1" if the shutter is open.  However, I am getting always "5".  I am unable to solve the problem. Can you please tell me the way out.
We are using serial to USB converter to connect the controller to the computer.
The manual is available online here:
Thanks in advance,
Message 21 of 32
(3,579 Views)
Your shutter status indicator is wired to the number of bytes written, not what the shutter is returning as a response.
You need to add a read function after your write to get the data returned by the shutter. Depending on how fast it responds, you may need to put a delay between the write and read operations.
-AK2DM
Message 22 of 32
(3,569 Views)
I have tried that and attached the vi. Please have a look.  This time I am getting write counts "5" and read counts "9", no matter if I keep the shutter open or closed.  I applied a delay of 5000ms after the write buffer.
Message 23 of 32
(3,554 Views)
sorry but it has been more that a year that I am not tweeking any VI, I am afraid I will not be able to help. I can send a the subVI I am using for my application, but it can only be more obscure as it has been modified and integrated in a huge Labview code. Let me know it you want it though.
Best
Message 24 of 32
(3,544 Views)
It will be great if you send me the vi....May be I can learn something and solve the problem...It has been for a few days that this problem is bothering me.
thanks,
Message 25 of 32
(3,539 Views)
This is Jeremy from Thorlabs.  Can you send an e-mail to techsupport@thorlabs.com please?  Can you also save your VI for LabVIEW 2011 please?  Thanks.
Message 26 of 32
(3,533 Views)
Hi Jeremy!
I have uploaded the 2011 version of the vi.  The thorlab technical support is very nice and  working on it but they nee bit longer time.  Since I stuck for a while for this shutter, therefore I posted in the forum.
Message 27 of 32
(3,528 Views)
Hello, I'm in same problem with you...
Did you solve that problem? If so, Please tell me how can I solve it..
Thank you for reading my message and I really want to solve it..
Message 28 of 32
(3,411 Views)
I have attached the vi from thorlabs.  This will definitely solve the problem.  You may customize it according to your application.
Message 29 of 32
(3,407 Views)
sorry I forgot to mention that you have set the baud rate to 9600, else it will not work.  If you have further question please let me know.
Message 30 of 32
(3,406 Views)
