To control shutter SC10
I have used Labview extensively. The library I downloaded from thor labs does not work. Someone said they could send help, they cracked this problem? Isw there anyone out there who might help?
Message 31 of 32
(1,043 Views)
You can use the basic example on how to do serial commands in LV from http://forums.ni.com/ni/attachments/ni/140/72646/1/Write%20to%20serial%20port%20basic.vi
You will first need to set the baud rate to 9600.  Section 4.4 of the manual list the commands and syntax you need to communicate with the shutter controller.  You can find the manual on Thorlabs' website: https://www.thorlabs.com/_sd.cfm?fileName=8654-D02.pdf&partNumber=SC10
Message 32 of 32
(1,036 Views)
