Transfering data from instrument to PC
Hi Im a student from taiwan.Recently i had a school projact  to control  vna.
I use lan to connect r&s znb.I check a lot of scpi command for loading and saving data,but i didn't find any about lan option for saving data ,just some command like
:MMEMory:STORe:TRACe  'C:\Users\Public\Documents\RohdeSchwarz\Vna\Traces\Chn1.s2p'Then I manulay control my vna but in saving dialong surface i can' find about lan option.
Can some one tell me about store data and load data with lan scpi command?
Orz i truly appericate.
Message 1 of 9
(8,668 Views)
Accepted by liom88792
That ":MMEM:STORe" command is usually for saving data locally on the VNA.  You want to look at the "MMEM:TRANsfer"  commands and examples.  It doesn't matter if its a LAN, USB or GPIB physical connection, the SCPI commands work the same regardless.
If you are using LabVIEW, check to see if R&S has a driver, I'd bet there's an example in there you could use.
Craig
Message 2 of 9
(8,608 Views)
Tank you very much.This is very helpful for my project.
And last time you help me solve the problem   #keithley 2611b-l source meter
the project i have done really appreciate.
I puy my project  photo
Message 3 of 9
(8,591 Views)
Glad I could help. GOod luck with the rest of the project.
Craig
Message 4 of 9
(8,562 Views)
HI  Craig i got some problem,i send command from the example you told me
 :MMEM:TRANS? 'ttest.s1p'  but i got this response  (i upload the photo )
i think vna can't read some kind of :MMEM:TRANS or i miss someing i gues
please give me some advise thank you very much ! Orz
Message 5 of 9
(8,510 Views)
Check your code, it looks like you forgot the ':' at the start.  I say this because the error message states :outp:mmem:... which isn't a valid command and thus the header unsupported error.
R&S manual is online here..
https://www.rohde-schwarz.com/webhelp/ZNB_ZNBT_HTML_UserManual_en/ZNB_ZNBT_HTML_UserManual_en.htm
From the manual this looks to be the preferred method..
https://www.rohde-schwarz.com/webhelp/ZNB_ZNBT_HTML_UserManual_en/Content/668d9dcebd3c454e.htm
/ Reset the analyzer
*RST
:SYSTEM:DISPLAY:UPDATE ON
:SENSe1:CORRection:COLLect:METHod:DEFine 'Test', TOSM, 1, 2, 3, 4
:SENSe1:CORRection:COLLect:SAVE:SELected:DEFault
// Initiate a complete sweep
:INITiate1:CONTinuous OFF; :INITiate:IMMediate;*WAI
:MMEMory:STORe:TRACe:PORTs  1, 'ParserTouchstonePorts.s1p', COMPlex, 2
:MMEMory:STORe:TRACe:PORTs  1, 'ParserTouchstonePorts.s2p', COMPlex, 3, 2
:MMEMory:STORe:TRACe:PORTs  1, 'ParserTouchstonePorts.s4p', COMPlex, 1, 4, 3, 2
Message 6 of 9
(8,481 Views)
Message 7 of 9
(8,469 Views)
Hi Craig, thak you for replying me . But i still have problem, i put on the photo about mmem scpi command,there is not :mmem:tran?  or sort  of thing.And i found that  about block data , it say Header:Header # 45168XXXXXXXX.
i read the explain but i don't know how to ask my znb header.
Message 8 of 9
(8,457 Views)
sorry I'm very annoying Craig. I figure it out
I send the command "Form:DATA REAL" for change the way instrument transfering data to binary
and then  I make a measurement  and read the data "CALC:DATA:TRAC? 'Trc2',SDATA"
after that i got python erro waring can't decode by "utf-8".
then i do some serching,and i use the read_binary_valus function and i got the right data.
For people not using pythonvisa or you use read_raw function,  when you read data you wii got some like this
b"#18\x84\xb3'4\xf0\x84c8" you need to parse it  the "1"behind the "#"indicates how many of
the following digits describe the length of the data,in this one is one ,"8"meaning the data is 8 byte
and you need to parse it \x84\xb3'4\xf0\x84c8. I use python it have a function struct.unpack(fmt,x)
in this example i just do one point sweep and i got two float data so sthat struct.unpack (<2f,a)
a=\x84\xb3'4\xf0\x84c8,  in the c#  it got something like that i don't know detaily, you can google it.
Hope that can help someone like 3weeks ago me.
Message 9 of 9
(8,384 Views)
