Transition not showing on LabVIEW Digital Waveform Graph when using Tektronix instrument driver
Could you save a vi with the data in the graph?
(make current values default)
Then we can try to see what is happening.
greetings from the Netherlands
Message 11 of 14
(1,399 Views)
Hi Albert,
Thanks for the offer to help!
I just sent the scope off for someone else to use for a while. I'll take you up on your suggestion when it comes back.
Message 12 of 14
(1,398 Views)
Hey there,
I work in the Instrument Driver R&D group here at NI and after some digging, I ended up finding a MDO4104 and a logic probe so I could try and verify the behavior that you're seeing. I fed the instrument a simple square wave on lines 1 and 2 from an FGEN and found that the Digital Graph is certainly giving me some strange behavior. It's not as blatant as what you posted in your screenshots but it's still unexpected. Since I don't have a ton of experience specifically with Digital Graphs, I'm going to talk with some of our LabVIEW guys here to see if they can make sense of what is going on and figure out whether this is a LabVIEW issue or just a mistake that was overlooked in the development of the instrument driver. I'll keep you posted on what I find out.
Lars L
IVI/Instrument Drivers
Message 13 of 14
(1,368 Views)
Hi Lars,
Thanks so much for taking a look into that! I still don't have the scope back but please let me know what you find.
Message 14 of 14
(1,361 Views)
