Trouble communicating with a GPIB instrument using VISA functions
Hi all,
I am trying to create subvi's that will allow communication between a computer and a MS260i spectrometer. This is an old spectrometer, and can only be interfaced via GPIB or RS232. I have chosen to use a GPIB-USB-HS adapter to connect it to the computer. The following settings in NI-MAX allow me to easily send commands to the spectrometer when using the NI-488.2 communicator. I have also attached an image of a successful wavelength query.
However, I am unable to make a subVI with the same settings. For instance, the following VI
returns the following error
Is there something I am forgetting? I also noticed that even though I saved the GPIB interface properties, these do not come up by default when using the NI-488.2 Communicator. Indeed, I have to manually configure the EOS settings each time I reopen the tool.
Any help would be greatly appreciated.
(4,365 Views)
Accepted by fthouin
Did you right click on the string control and select '\'Codes Display? If you don't, the termination character is not being sent.
(4,348 Views)
I suggest to write EOI automatically
And please attach you vi.
Are you editing the string in \ mode or in normal mode?
You can check that by selecting the string and rightclick and look at the display mode of your commandstring.
If \ mode is active there is something strange happening, but otherwise you are not sending the end character 10 but a real \ and an n.
This is different in LabVIEW compared with MAX.
(4,345 Views)
My good sir, you are a genius.
(4,324 Views)
