Trouble installing driver for GPIB-USB-HS on Linux
I need to install a GPIB-USB-HS driver for my Linux system:
Red Hat Enterprise Linux Client release 5.2
2.6.18-92.el5 kernel
I have tried installing NI-488.2 v2.5 1b1 (beta 32-bit) and NI-488.2 v2.5.4b1 (beta 64-bit). Both installs gave me the same error:
ERROR: make of nikal kernel module failed, not installing kernel module.
   updateNIDrivers should be called again after fixing the problem.
   Logging failure...
   Include the file /tmp/niSystemReport.out.gz when contacting
   National Instruments for support.
When I run the updateNIDrivers it gives me the following:
*********************************** ERROR ************************************
*                   ERROR: . kernels are not supported!                    *
* Running a 2.4.x or 2.6.x kernel is required to continue this installation. *
/usr/bin/id: unrecognized option `--skip-alias'
Try `/usr/bin/id --help' for more information.
./uninstall.sh: line 24: [: !=: unary operator expected
/usr/bin/cat: unrecognized option `--skip-alias'
Try `/usr/bin/cat --help' for more information.
/bin/uname: unrecognized option `--skip-alias'
Try `/bin/uname --help' for more information.
Removing NI-KAL (nikal): /usr/bin/rm: unrecognized option `--skip-alias'
Try `/usr/bin/rm --help' for more information.
/usr/bin/rmdir: unrecognized option `--skip-alias'
Try `/usr/bin/rmdir --help' for more information.
done
/bin/rm -rf objects
Updating NI-KAL:
 NI-KAL successfully updated.
Updating client modules:
/usr/local/natinst/nikal/src
 ni488lock.ko successfully updated.
 ni488k.ko successfully updated.
 nipalk.ko successfully updated.
Rebooting is required to ensure that National Instruments drivers
have been successfully updated.
Would you like to reboot now? [yes|no]
I have also attached the niSystemReport.out.gz file.  What driver should I be using?  Any suggestions would be appreciated.
(3,623 Views)
kesselg,
I would suggest trying a couple of things to see if we can eliminate this error.
1) Try installing the latest version of the NI-KAL driver (NI-KAL 1.10) separately and then install the NI-488.2 driver.  If the version of the NI-KAL shipped with NI-488.2 is too old, it may cause the failed installation. The driver can be found at the location below.
http://joule.ni.com/nidu/cds/view/p/id/1304/lang/en
2) If this does not work, I would suggest installing an older version of the GPIB driver and see if the same error persists.
Raj
Applications Engineer
(3,603 Views)
Raj,
Thanks for your response.  I ended up going back to NI-488.2 v2.5 1b0 (Beta0) which worked.
Grant
(3,586 Views)
