Troubleshooting NI Instrument Simulator Version 1
I am using a straight through cable.
I will post the NI Spy info late today.
Thanks for all the ideas.
Message 11 of 17
(2,369 Views)
I don't see any place in the manual that explains which type to use. In my experience, the majority of serial instruments require a null-modem.
Message 12 of 17
(2,364 Views)
Interesting... Since the manual called for a serial cable that supports hardware flow control and never mentioned null modem, I assumed I needed a straight through cable.
Could someone that at NI verify which cable that I need?
Thank you,
Message 13 of 17
(2,360 Views)
Accepted by topic author dpitcher
Have you seen this. I don't know if this KB article refers to the simulator model that you have or to the version 2 type. The help file for the version 2 type is definite about the need for a null modem cable.
Message 14 of 17
(2,350 Views)
Thanks for the info. I will try it with a null modem cable and see how it works.
Message 15 of 17
(2,344 Views)
Our NI Instrument Simulator requires a null modem cable.
Steven Zittrower
http://www.ni.com/support
Message 16 of 17
(2,343 Views)
The lack of a NULL modem cable was the problem.
I thought the Instrument Simulator manual would have mentioned something as vital as needing a NULL modem cable. Seems odd to me that the manual goes so far as to state the cable needs to support hardware flow control, but neglects to mention NULL modem.
Thank you oh great Knight who says NI. And, thank you Steven.
Message 17 of 17
(2,323 Views)
