Turtle ph-meter serial interface
The same wishes to you.
And you are doing well, nice work.
greetings from the Netherlands
Message 11 of 12
(1,239 Views)
Hi, I'm back on this problem again. Basically I understood that what I need is a way to interface a IC : TCL549 made by TI via the serial port through the Labview 8.2 (of course).
I wondering if nobody did it already. I found this link :
but they didn't used the serial port and they managed it by another hardware directly. None of the Ni engineers can give me more direct references to my problem ?
Thanks in advance.
Gianmarco
Message 12 of 12
(1,195 Views)
