Two HP3458A synchronous triggering - time delay
Accepted by Tina2
First question: What type of signals do you want to measure simultanously?
We had a similar task, finding the time (group) delay between a scopecard and a 3458. We used a sine generator, captured the same signal on both devices (20-100 periodes) , and used the tone detection (and a linear sine fit) to determine the group delay.   With a stable generator this worked out nice even with sub sampling (RIS) the signal on the 3458 using a >100kHz sine signal.
Make shure you have a clean good trigger signal for the HP äh AG äh .... How do they call them know?? 😉
If I remember right the uncertaincy we got remain in the single digit ns region..
Dennis: In some cases it is still hard to find an instrument that will beat the 3458 🙂  and in the frequency range up to 12kHz (direct sampling with the 3458) I don't know of somthing beating the uncertainty. Next : If you have two 3458 it will sometimes be hard to get the money for a nearly compareable two channel system..
Finally: The joy of engineering is to do what you what with the stuff you can get! 🙂
Greetings from Germany
Henrik
LV since v3.1
Message 11 of 12
(2,687 Views)
HI, Henrik.
Answer: AC sine signal.
Yes, there are Hewllett Packard (HP) and Agilent (AG) 3458A instruments.
I'll write to you soon as I generate more questions! 🙂
Message 12 of 12
(2,676 Views)
