UNO-2050CE-GDA1 with labview
hi folks,
just wondering if its possible to use UNO-2050CE-GDA1 hardware connected to pc(or its come with windows CE 4.2) by labview and use all the i/o port from UNO-2050CE-GDA1 to make a control system as a plc.
here is the data sheet http://www.delvingware.com/webservices/medialibrary/media/datasheets/UNO-2050CE-GDA1.pdf
if anybody know anything about this hardware, will you please help me out here?
thanks in advance.
(3,935 Views)
anybody?
can i use modbus tcp/ip protocol? can i use visa?
(3,919 Views)
helllo again,
i seriously need some help to make a exe file in windows ce 5 platform to control this hardware DI/O.
this hardware comes with Example of C, C#, VB6 and VB.NET.
also there is SDK for this product.
now i want to make a simple exe vi which i can run on this windows ce to control the DI/O.
after lots of reading i found lots of way to do it.
inline C command
driver wrapper....
can you please recommand me one which is easy and suit all my need before i look into deep.
thanks
(3,852 Views)
Hi homeauto,
Labveiw .exe's are supported on windows CE I would suggest using the inline C command as a good option if you are familliar with C coding.  If you want to create a custome driver for the UNO-2050CE-GDA1 then here are is a link about driver creation.
http://digital.ni.com/public.nsf/allkb/796F187241DF36D1862576F20059366D?OpenDocument
Matt Surridge
(3,846 Views)
This may also be of interest.
http://digital.ni.com/public.nsf/allkb/E3485A8B93929DAC862572D6005240EF?OpenDocument
Matt Surridge
(3,845 Views)
