USB-6001 -200361 error via enabled overwrite option
I am collecting Analog data in real time with a USB-6001. (300hz, 100 samples) I am also using 485 and 232 communication via USB to communicate with external devices. Each communication has a period of about 100ms.
My question is that my USB-6001 is intermittently throwing a -200361 error. This is an overflow error, so I enabled the overwrite option. However, this did not solve the problem.
I am confused as to why I am getting an overflow error when the overwrite option is on.
Is it possible for this error to occur in cases other than overflow? (Also, sometimes the 485 communication has timeout errors and terminates. I'm not sure if this is a related issue and we're working on that as well).
Thank you!
(913 Views)
Please share the code you're using to control USB-6001
Santhosh
Soliton Technologies
(879 Views)
