USB 6008, NI-DAQmq 16, LabVIEW 2011- not DAQ Assistant, no connecting USB
Good day!
Please, help my!
Есть USB 6008, NI-DAQmq 16, LabVIEW 2011. В блок-панели почему-то нет установленного DAQ Assistant. Был Instrument I/O Assistant, но он указывал на ошибку при установке.
Я проверил по списку установленных компонентов, не было NI-VISA. Скачал и установил.  DAQ не появился, но Instrument I/O Assistant начал требовать данные по устройству, не замечая соединение по USB.
Подскажите, как действовать?
Заранее благодарен всем, кто что-нибудь подскажет!
(2,611 Views)
Accepted by topic author GarryHo
Hi GarryHo,
I'm not sure if I understood correctly but for what I can see, you have a USB-6008, this device is not controlled via VISA, there are specific drivers for it, which come in the NI-DAQmx package. If you can't communicate with it and do not have the DAQ Assistant on LabVIEW, there must be something wrong with the installation.
I think the error comes from the compatibility of the Software you have installed on your computer. As you can see here, LabVIEW 2011 is not compatible with DAQmx 16, the last version compatible with LabVIEW 2011 is DAQmx 14.5.1, so you have to install that version on your computer to use the DAQ Assistant. Hope this helps!
(2,578 Views)
