USB DRIVER FOR POTENTIOSTAT PAR 2273
Hello!
I need to control a usb equipment. This equipment is a potentiostat, model Princeton Applied Research PAR 2273.  I think I can control it using NI-VISA. But I need the driver of this equipment. Do you know where can I found it? Is possible to control this kind of equipment using NI-VISA and LabView 8.6??
Thanks a lot!
Hello!I need to control a usb equipment. This equipment is a potentiostat, model Princeton Applied Research PAR 2273.  I think I can control it using NI-VISA. But I need the driver of this equipment. Do you know where can I found it? Is possible to control this kind of equipment using NI-VISA and LabView 8.6??
Thanks a lot!
(4,488 Views)
probably the usb is just a serial line replacement and can be controlled by VISA.
I'm sorry I don't have a driver for this machine.
greetings from the Netherlands
(4,472 Views)
I have been looking for that driver, but seems that we don´t have it. You might be able to ask the producers for the driver or how to comunicate via USB or Serial in order to make the communication with NI VISA.
Can you see de device in the Computer?
Anyway I will still looking for it!!
Good Luck
Luis Elias
NI VeriStand and HIL Product Manager
(4,384 Views)
Hi, This is me again,
I´ve found some possible solutions for the issue.
http://www.princetonappliedresearch.com/Support-Center/FAQ-Hardware/How-do-I-install-and-configure-m...
Here are couple of forums that say how to connect your potentiostat with NI components.
Luis Elias
(4,383 Views)
Thanks Luis Elía. I will check it.
Muchas gracias!
(4,378 Views)
