VISA 5.0.1 problem ("Could not perform operation because of I/O error") when using Thorlabs Power meter (PM100USB)
We have integrated theThorlabs Power meter PM100USB (attached to S151C sensor) to our application.
We are using the following software components / layers:
  • PM100x_Instrument_Driver_V2.0
  • PM100D_Utility_V3.0
  • VISA 5.0.1
  • Running on Windows XP (Service Pack 3)
  • Application written in C#
  • VISA session connection string is USB0::0x1313::0x8072::P2000434::INSTR
Performing measurements in manual mode - works. No issues.
Trying to perform continous measurements (every 50-100 milli-seconds) causes the following failures:
Failure #1
Exception when calling PM100D_Drv.measPower - "Could not perform operation because of I/O error"
Notes:
  • Additional calls to measPower may succeed, or fail.
  • When such a failure occurs, the application stalls for 2 seconds.
  • This kind of failure happens quite frequently
Failure #2
Failure to connect to PM100USB upon application startup
ERROR: Insufficient location information or the device or resource is not present in the system
Notes
  • There is no workaround!!!   a reboot to the machine is required.
  • This kind of failure happens rarely (after some time when the system is in IDLE mode)
What could be the cause of these failures?
I have no idea how to resolve them.
Roy.
(3,370 Views)
Hey talster,
Since you are using third party instruments, I am not familiar with the drivers that seem to be giving you the errors. I would try talking to THORLABS about these issues, since they are responsible for maintaining these drivers. If they are not helpful, post back here and I will see what all I can find out. Good luck!
cheers,
~kgarrett
District Sales Engineer
(3,345 Views)
