02-09-2006 11:43 AM
02-09-2006 11:09 PM
02-10-2006 11:26 AM
02-13-2006 04:52 PM
02-14-2006 10:04 AM
Couple of things:
1) The GPIB-USB-HS is not officially supported with the Linux driver. According to the README, only the GPIB-USB-B is supported
2) It appears that you may not have Mandrake 10.0. Your kernel version is quite a bit newer. Run "cat /etc/*-release" and post the output, as well as the output from "uname -a". If you're running 10.1, that isn't officially supported either.
I'd still like to know more about your problem, but I want to warn you that this may not be fixable since it's not supported.
Scott B.
GPIB Software
02-14-2006 12:13 PM
02-15-2006 10:49 AM - edited 02-15-2006 10:49 AM
Message Edited by ScottieB on 02-15-2006 10:54 AM
02-15-2006 11:03 AM
I sorry, I made a typo - I spoke to Evan Robinson (who told me 488 driver does work with 10.1) on 5/18/05, nor 2004.
Re using the driver with the USB-HS under 10.1, I have quite a few apps that I have written, and they all work flawlessly (at least so far).
02-15-2006 11:13 AM
02-15-2006 06:26 PM
