10-14-2005 06:11 PM
10-16-2005 07:44 PM
You can't avoid that VISA resource name (in USB serial# part) dynamically changes for USB device that does not have serial#. However its nams is virtually static as long as the device is attached on the same HUB on the same computer. A good solution is use the VISA Alias feature for the device then communicates through the VISA alias instead of real VISA address, though it will be still needed to reconfigure the VISA alias whenever the real VISA address gets invalidated. Also there is no way to distinguish multiple same devices connected to the same computer.
10-17-2005 10:18 AM
10-17-2005 11:07 AM
10-17-2005 11:40 AM - edited 10-17-2005 11:40 AM
このメッセージは 10-18-2005 02:42 AMに Makoto が編集しています。
10-17-2005 05:16 PM
