USB-TC01 Linux device driver
Hello.
I want to connect USB-TC01 to a PC running Ubuntu OS to measure temperature.
While for Windows, it's as simple as installing the .exe file, I can't seem to find any manual for Ubuntu.
Could you please share any relevant information?
Thank you in advance for your response.
Message 1 of 8
(2,229 Views)
You need to install DAQmx driver for USB-TC01.
Please download the linux drivers from https://www.ni.com/en/support/downloads/drivers/download.ni-linux-device-drivers.html#521765
https://www.ni.com/en/support/documentation/supplemental/18/daqmx-for-desktop-linux-tools.html
Santhosh
Soliton Technologies
Message 2 of 8
(2,186 Views)
I installed the package through the link you provided and the Readme, and I confirmed the following screen.
Although the Readme indicates that temperature measurement with TC01 is possible on Ubuntu 22.04, in the current environment, it shows that the device is not supported, as shown in the picture.
Is this correct? If there is anything I missed, please let me know.
Screenshot from 2024-02-21 10-48-21.pngScreenshot from 2024-02-21 10-48-21.png
Message 3 of 8
(2,175 Views)
The fact that you can create a simulated device does not mean that this device is not supported by DAQmx, rather the contrary.
Rolf Kalbermatter  My Blog
Message 4 of 8
(2,158 Views)
So I installed it according to the manual, but while Windows has an .exe file, what should I run for Ubuntu?
The driver installation is complete.
Message 5 of 8
(2,146 Views)
What EXE file? If you mean NI-Max, that does not exist under Linux and is getting depreciated under Windows too. The new way to configure hardware is the NI Hardware Configuration utility which exists on Linux and Windows. And I think you already found that as your previous screenshot shows.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019Y2XSAU
https://www.ni.com/docs/en-US/bundle/hardwareconfigurationutility/page/definition.html
Message 6 of 8
(2,124 Views)
The attached photo shows that in a Windows environment, I can use such a program to check the temperature.
I'm curious if there's a similar program for Linux.
Please also explain how to set it up.
Thank you in advance for your answer.
Message 7 of 8
(2,087 Views)
The app in the image is loaded from USB-TC01's memory and looks like it supports only Windows.
https://www.ni.com/en/support/documentation/supplemental/10/what-s-included-with-the-ni-usb-tc01-.ht...
Santhosh
Message 8 of 8
(2,080 Views)
