USB Timeout (0xBFFF0015) Chroma 63200A
i tried to find a solution for my problem in the forum, but i could not find any solution. I try to control the device via USB.
I can set and read the CR-options, but any other specific READ-command will fail with a timeout
VOLT:L1?
Read Operation
Error
VISA:  (Hex 0xBFFF0015) Zeitüberschreitung, bevor der Vorgang abgeschlossen werden konnte.
Any SET-Command does nothing - no change in the display.
VOLT:L1\s120
I already tried to change the VI_ATTR_TMO_VALUE, but still no success.
Thank you for your help in advance.
best regards
hschenk
(4,729 Views)
Hi
I don't understand the CR-options or do you mean the end of line constants.
So show us your code and we can help better.
greetings from the Netherlands
(4,701 Views)
Sorry, my mistake. CC, CR, CP, CV means the load options of the chroma device. (CC = constant current, CR = constant resistance etc.)
I can set the different options for CC (not CR as i mentioned in my first post - my mistake). Any other option will not work via USB control. I will test the commands with the VISA interactive control. I can identify the device via *IDN? and control the CC-Options, but commands like the following ones do not work, because of the timeouts. The newline command '\n' will be added automatically when i execute the command.
How can i fix the problen und what could be the error cause?
(4,681 Views)
Accepted by HSchenk
Everythin works fine. Manuel/commands of the device are insufficiently described.
(4,675 Views)
Hi!
I dont understand your solution. Can you explain more specifically?
(714 Views)
