USB Virtual Serial Port on RoboRIO for DecaWAVE
I am working on an evaluation project using the DecaWave Trek1000 which is an evaluation platform for  position tracking system.  On my windows PC I plug in the device via USB and it sees it but has errors and is unusable till I install the virtual com port driver and all is well.
If you are familiar with the DecaWave I am useing the 2.10 version of the firmware.  There is a newer version but I am waiting on my JTAG to upgrade but I am not sure that will solve my problem.
I hope to setup and use the Virtual COM port on my RoboRIO so I can see my streaming data coming in.  So the RoboRIO sees the USB device when plugged in but shows it as not present and I cant access it.  Basically the same response as when I plug into my Windows PC until the driver is installed.
I assume that I can use a Linux driver on the RoboRIO and all will be well but I cant find oney yet.  Alternatively LabVIEW is pretty smart and can create a generic driver which will just give me raw data and parse it out.  Unfortunately the USB looks to be missing data to allow me to do this using the wizard (See Error below).
Any help would be greatly appreciated!
(3,533 Views)
Hmm, it seems like you might be missing some drivers or maybe they were downloaded out of order.
According to the readme for the roboRIO product:
http://www.ni.com/pdf/manuals/375390b.html
The requirements for the roboRIO are the following:
  • LabVIEW Development System
  • LabVIEW Real-Time Module
  • LabVIEW roboRIO Toolkit
Do you have these modules?
(3,461 Views)
Also are you working for FIRST robotics competition?
(3,459 Views)
