07-06-2018 04:03 PM
I am attempting to use a USB to RS232/4 device. My application involves using this device remotely (>100m) and, ideally, with an Ethernet connection. I have attempted to use a USB to Ethernet adapter to communicate with this device to no avail (communication using USB is fine).
Has anyone been successful in communicating with a USB to RS232/4 device over Ethernet and could you share how you were able to do it? I realize this may not be possible.
Thank you for your help,
Dan
Solved! Go to Solution.
07-08-2018 06:34 AM
I think you will be better off just getting an Ethernet to RS-232 adapter, such as this one: NETRS42348PD
07-12-2018 09:48 PM
Thank you crossrulz. That is what we are going to do.
Dan
