Unable to Communicate with PC to Instruments
I am not able to see the instrument in the measurement & automation. Do I have to configure the instrument in order to see them in the MAX or should they appear in the MAX and then I configure them?
Message 11 of 17
(2,142 Views)
How do they appear in the windows device manager? Are they listed as USB TMC (Test and Measurement Class)? Did you get a USB driver from the vendor and did you install it? Since you keep getting prompted for a driver, it would seem that there is a problem there. This driver is completely separate from the instrument driver you would download from NI.
Message 12 of 17
(2,132 Views)
Hey Dennis,
I do not have USB driver. One did not come with the instruments, should I be able to download one from the company website?
Message 13 of 17
(2,110 Views)
I just took a look at the Agilent 3K scope manual. The only mention of the USB port talks about using the port to connect a mass storage device to save/recall files or to connect a printer. The programming manual only mentions the RS-232 and GPIB ports for remote control. Do you actually have some information from Agilent that the USB can be used for remote control? I have not looked at the manual for the Tek scope but the data sheet does not mention the USB port for programming either. I saw a mention of the USB port for a mouse connection. You should really contact the vendor about how the ports are supposed to be used.
Message 14 of 17
(2,103 Views)
Hey Dennis,
I'll contact them now, probably should have done this before starting. Thanks for starting where I should have. I'll let you know.
Message 15 of 17
(2,097 Views)
I am know able to communicate with the instruments, required using ethernet or GPIB.
Is there any VI's that are avalible that are replicated front panels for the 2 instruments.
Message 16 of 17
(2,062 Views)
Hello all,
 This is the answer from Agilent:
 http://forums.tm.agilent.com/phpBB2/viewtopic.php?t=3329
Message 17 of 17
(1,735 Views)
