Unexpected error and exception in MAX Explorer
Hi everyone,
I have some problems with the Measurement & Automation Explorer. When I try to open it there is an error about the MAXKnownException. If I press for more details I get the next information:
The niGPIBsys.dll plug-in caused an exception in the CmxSysExpertManager::FinalizeExpert function in the NIMax process.
I am using Windows 7 and LabView 2012 Student Edition (everything updated).
Problems started when I downloaded and installed NI Device Drivers. All I wanted is to use Simulated NI-DAQmx. When I ignore the error and create Simulated NI-DAQmx it doesn't work properly. Trying to Self-Test created device is causing another error, something about device not connected.
After installing NI Device Drivers new update came up: NI 488.2 but it also didn't resolve the problem. Repairing installations like: LABView, MAX, installing again NI Device Drivers also didn't help.
Thanks in advance.
PS: I used the same installation files on my second computer with XP installed and everything works fine, without any problems. So it must be some problem connected with Windows 7?
(3,784 Views)
Try this:
http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/Unexpected-error-and-exception-in-Measurement...
I had a similar problem and I solved it. Hope it will help!
(3,747 Views)
