Uninstalling the ni visa 3.0.1 to install 4.2
Hi all,
I need to install ni visa 4.2, however I need to uninstall ni visa 3.0.1 first to let 4.2 be effective.
But I have some problems to uninstall the ni visa 3.0.1.
I'm waiting for your help for instructions to unistall it.
Thank you
(3,673 Views)
@basar wrote:
Hi all,
And these would be...? Please provide specifics. Otherwise the only advice we can give you is: Run whatever control panel is applicable for your operating system and run the uninstaller for NI VISA.
(3,643 Views)
"But I have some problems to uninstall the ni visa 3.0.1." does not explain anything. What is the exact nature of the problem? Did you select 'NI Software" when running the windows uninstall program?
(3,638 Views)
Accepted by basar
Thank you for your attention.
I'm new on this. I've just found out how I can uninstall from add/remove part from control panel.
Thanks for your time
Problem is solved.
(3,634 Views)
