Using USRP 2900 Wirelessly
Is there any method by which we can use NI USRP 2900 without connecting it to the host PC via USB cable?
(1,762 Views)
Accepted by topic author new_user197
no, you should connect the USRP 2900 device to the host PC using USB cable to use it. You can connect the device to either a USB 3.0 or USB 2.0 port.
Kindly refer to the USRP-2900 Getting Start Guide.
(1,708 Views)
