VI_ERROR_RSRC_LOCKED
i have a hardware configuration, where several power supplies and a multimeter are connect on one GPIB bus to a USB2GPIB device(Agilent 82357). On the PC I want to control the power supplies and the multimeter from different programs. Both programs open a session with viOpen(.., VI_EXCLUSIVE_LOCK,...), both programs set the timeout value to 50s with viSetAttribute(..., VI_ATTR_TMO_VALUE, 50000).
Any program works as long as the other is not started.
But if, e.g. the power control program is running (showing the actual currents) and I start the multimeter, some power readings failed with:
Error to get current: -1073807345 VI_ERROR_RSRC_LOCKED: Operation failed due to
locked resource
This is the error returned from
ErrorStatus=viPrintf(g_ps[psm_id-1].ps_sesn,"MEASure:VOLTage? (@%d)\n",output_id)
or
ErrorStatus=viScanf(g_ps[psm_id-1].ps_sesn,"%f",&value)
. After some seconds, both programs continue without any error anymore.
Does anybody has an idea, how I can avoid the collision of both programs. For my understanding these shall be happend by the locking of the resources. But it seems not to work. Any ideas?
David
(6,165 Views)
Search
Go through all the posts and if still your problem was not solved, please post back.
Markus
(6,076 Views)
