VISA: (Hex 0xBFFF001D) The specified attribute is not defined or supported by the referenced resource.
I have an NI PXIe-1073 Chassis which is having a timeout error. I have noticed this on the view attributes function for that card. Does anyone know how to fix this or anyone with a similar problem?
BackPlaneError
It's causing a lot of timeout errors.
Thanks a lot.
Best.
(4,162 Views)
Hi PhotonNinja,
I am an Application Engineer from NIUK.
I have a couple of questions for you:
1. What is your hardware setup?
2. What NI software do you have? (Attach a MAX report)
3. What are you trying to achieve?
4. What OS?
I look forward to hearing from you
Kind Regards
Kevin R
National Instruments UK&Ireland
(4,118 Views)
