Visa Open Error code 1073676413
I want to interface Keithley 2400 sourcemeter with the computer. I have a KUSB 488A GPIB to USB converter from Keithley as connection between the sourcemeter and computer. I have installed the GPIB drivers using the CD provided with the sourcemeter. Before installing LabTracer 2.9 software, I installed the following prerquisites:
-- Microsoft .NET Framework 1.1 (dotnetfx.exe)
-- LabVIEW Runtime 7.0 (LVRunTimeEng.exe)
-- Visa462runtime
 After successfully installing these, LabTracer 2.9 opens. But when I run the device test in the software, I get the following error window  named 'Run Time Engine':
 'Their was an error reported on Visa Open. Test aborted. Error code: 1073676413.'
I also tried installing some higher versions of the prerequisites but the same problem persists.
Please help me to fix this problem.
I have also attached a screenshot of the error message.
(4,677 Views)
-- Visa462runtime
Why are you posting here?
The KUSB 488! is not a NI device. You are using their software.
None of this has anything to do with National Instruments.
Contact Keithley.
(4,664 Views)
