VISA Read Double Precision Number Corruption with the Keithly 2400
I am stumped on this item.  I have two PXI systems with built in GPIB controllers.  One of the systems randomally started showing behavior where the double precision read commands returned gibberish data.  On the other system, I am using the exact same code and everything works.  Standard String commands work just fine (set voltage, set current, query set voltage etc.).  I have tried the following:
Reset computer
Swapped Keithly instruments (the problem follows the PC)
Swapped GPIB cables
Updated 488.2 driver
Used seperate HS-USB to GPIB controller.
I will be reinstalling NI-VISA as well.
The only difference is that I installed some other LeCroy instrument drivers to the failing system.  But the problem didn't occcur after I installed the drivers, it occured while my code was running.
Has anybody ever seen this before?  What could other causes be?
(3,467 Views)
seems like the problem could be that the power of the gpib is not good or the speed a bit too high.
Did you try to set the speed of the gpib to 1microsecond?
Just a lucky guess maybe but the 2400 is ot very fast and if power supply is scarce it could be the problem.
(3,460 Views)
Thanks, I will look into it.  The real problem is that I have another identical system (initially) where everything is running just fine.  And it has worked for 2 years previously.
(3,459 Views)
Accepted by BSteele
The problem was with the Keithley, it was changing the format of the data without my knowlege.
(3,417 Views)
