VISA Write.vi Options for the Write Buffer
For now I am not working with any hardware, I was just running the read write buffer within my pc only. I will try to send the 2018 file. But for now, I am attaching the snip shots. Also, I have checked and VISA Write return count is not wired to the VISA Read Byte count.
Thanks for quick reply
Message 11 of 12
(483 Views)
You are missing the point of VISA.  VISA stands for Virtual Instrument Software Architecture - https://en.wikipedia.org/wiki/Virtual_instrument_software_architecture
Its an API for controlling instruments, so in your code you are asking the VISA Write to send a command "Good" to VISA Resource name "COM1" using a serial bus. You then try to read a reply from COM1, after checking if there are bytes at port.  So unless you physically have a device or an emulator ready to reply to the "Good" command you will never have a reply.
Here's a good introduction on how to properly use serial instruments in LabVIEW.  (Hint: DO NOT USE BYTES AT PORT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! © crossrulz)
https://labviewwiki.org/wiki/VIWeek_2020/Proper_way_to_communicate_over_serial
If instead you are looking at a way for programs to communicate between each other then look here - https://zone.ni.com/reference/en-XX/help/371361R-01/lvcomm/labview_comm/
Hope that helps.
Craig
Message 12 of 12
(468 Views)
