VISA error: Use the VISA to initialize the 61604(ac source) 1073807343 error code
Dear everyone:
      I have the problem of initailize the 61604 (ac source) by VISA . The error code picture as below.
---first, I can see the instrument 61604 on the MAX , and I can communicate with instrument by MAX. I sent *IND string to 61604 ,then MAX can Received the string like ''chroma ATE,61604,001634,1,25,1.34,1.20........So Can I ensure the 61604 communicate with MAX well?
---second, I see the VISA name of 61604 instrument is "61604_1" the same as the INITANILIZE.vi.pls see the picutre as attached.
    So what confused me is that 61604 can communicat with MAX , and the instrument VISA name in the INITANILIZE.vi is the same as MAX.
   Why always error????
Message 1 of 12
(5,476 Views)
Also I can open the VISA test panel ...picture as below
Message 2 of 12
(5,474 Views)
Update the picture of error
Message 3 of 12
(5,473 Views)
That's an error from an IVI function. Did you define the IVI setup in MAX?
Message 4 of 12
(5,467 Views)
Dear Dennis:
     Thank you for U reply so soon! This is a error I first met.I don't know how to define the IVI funtion setup in MAX.Can U tell me how to do it .but I think I had done IVI funtion setup..pls refer to below picture.
     second, I want to said is this initianlize.vi that I can run in the tester yesterday.But today I power the PC and find this error.
  Thanks!
Message 5 of 12
(5,463 Views)
When you open MAX, you should plainly see a link to configure an IVI driver.
Message 6 of 12
(5,458 Views)
Hello:
    Thanks very much! But can I confirm that the IVI dirver is ok, what I need to do  just setup the IVI in Max.
Message 7 of 12
(5,444 Views)
Dear Dennis,
   I found the 61604 IVI setup in Max.(refer to picture). But I find the boot of the error. In Initialize.vi ,I put into the name is 61604_1, however , I refresh the resource name which show instrument name is GPIB::.....NOT 61604_1.
   So, how can I make instrument show 61604_1 in the resource name?
Message 8 of 12
(5,427 Views)
Hi:
    U re right...The IVI dirver setup is empty.  Is that the reason????
Message 9 of 12
(5,424 Views)
It is the logical name that is used with IVI as you can see in the initialize function. Why are you looking under driver sessions?
Message 10 of 12
(5,415 Views)
