07-06-2012 04:17 AM
Dear everyone:
I have the problem of initailize the 61604 (ac source) by VISA . The error code picture as below.
---first, I can see the instrument 61604 on the MAX , and I can communicate with instrument by MAX. I sent *IND string to 61604 ,then MAX can Received the string like ''chroma ATE,61604,001634,1,25,1.34,1.20........So Can I ensure the 61604 communicate with MAX well?
---second, I see the VISA name of 61604 instrument is "61604_1" the same as the INITANILIZE.vi.pls see the picutre as attached.
So what confused me is that 61604 can communicat with MAX , and the instrument VISA name in the INITANILIZE.vi is the same as MAX.
Why always error????
07-06-2012 04:30 AM
Also I can open the VISA test panel ...picture as below
07-06-2012 04:36 AM
Update the picture of error
07-06-2012 08:04 AM
That's an error from an IVI function. Did you define the IVI setup in MAX?
07-06-2012 08:41 AM
Dear Dennis:
Thank you for U reply so soon! This is a error I first met.I don't know how to define the IVI funtion setup in MAX.Can U tell me how to do it .but I think I had done IVI funtion setup..pls refer to below picture.
second, I want to said is this initianlize.vi that I can run in the tester yesterday.But today I power the PC and find this error.
Thanks!
07-06-2012 08:53 AM - edited 07-06-2012 08:54 AM
When you open MAX, you should plainly see a link to configure an IVI driver.
07-06-2012 09:45 AM
Hello:
Thanks very much! But can I confirm that the IVI dirver is ok, what I need to do just setup the IVI in Max.
07-06-2012 09:18 PM
Dear Dennis,
I found the 61604 IVI setup in Max.(refer to picture). But I find the boot of the error. In Initialize.vi ,I put into the name is 61604_1, however , I refresh the resource name which show instrument name is GPIB::.....NOT 61604_1.
So, how can I make instrument show 61604_1 in the resource name?
07-06-2012 10:36 PM
Hi:
U re right...The IVI dirver setup is empty. Is that the reason????
07-06-2012 11:38 PM
It is the logical name that is used with IVI as you can see in the initialize function. Why are you looking under driver sessions?
