VISA viOpen cause an interrupt to other instrument (GPIB Chip NI-9914) when running multiple instruments with Fast PC (P4 > 2.8GHz) using NI-PCI GPIB card.
Hi GPIB Guru,
Thank you very much for your help.  The problem is gone.Smiley Very HappySmiley Very Happy
I only follow your step 1 and step 4.  Do I still need Step 3?
But step 2 you suggest will not have viAddress reuse, unless I put the another while loop outside the viOpen and viClose. I rewrote my program to reproduce the viAddress recycle from other instrument for the test.
Loop
        For i = 1 to 3 //(3 instruments)
             viOpen(Res(i), &viAddress(i)
Until Error
Thanks again
Message 11 of 15
(1,857 Views)
Hi GPIB Guru,
Loop
Until Error
Thanks again
Message 12 of 15
(1,858 Views)
Sorry, I press something on my key board, and it submitted the message when I did not complete yet.  Here it is..
Loop
             viOpen(Res(i), &viAddress(i))
       Next i
       For j = 1 to 1000   // Test Read/Write 1000 times
                      viWrite(viAddress(i), "CLOSE 1")
                       viWrite(viAddress(i), "OPC?")
                       viRead(viAddress(i), &Buffer)
               Next i
       Next j
             viClose(viAddress(i))
       Next i
Until Error
Message 13 of 15
(1,856 Views)
I probably should have made myself clearer. Each of the 4 solutions will work for you independently. That is, you can use any 1 of those solutions to solve your problem. Doing multiple of the solutions will be fine as well (just potentially redundant).
Glad that my hypothesis was correct. Good luck!
Message 14 of 15
(1,849 Views)
Thanks GPIB Guru,
I have tested, and step 4 is a must.  If the key DisableIbListen=0, the problem still exists.
Message 15 of 15
(1,839 Views)
