VISA
1.Hex transmission.
2.Use FF as anchor point.
Message 11 of 25
(1,820 Views)
Hi
I hoped for something with values, but I will check the source code, to see if this can be simplified.
Rest my question on how fast you want to measure, and for how long?
greetings from the Netherlands
Message 12 of 25
(1,815 Views)
The transmitted code is not written by me so there is no source code.only labivew code.
1.baud rate:9600
2.store time in milliseconds
3.The test time is indefinite.
Message 13 of 25
(1,809 Views)
Ok
I will write blocks of data max 100 elements per block in a separate while.
In the measure while I wait 1ms so each loop should give 1 measurement.
Opening the file before the loop and write a date stamp.
In the loop only write the time and both values to an array.
In this way the arrays are updated 10 times per second. Fast enough to eee something.
Later I will send the vi.
Message 14 of 25
(1,797 Views)
as promised the vi.
I changed a lot so if it does not work, just tell me.
Let it at least run a few seconds.
Message 15 of 25
(1,791 Views)
OK
Thank you for the help.
Message 16 of 25
(1,767 Views)
Is the test code the version you uploaded last time?
Message 17 of 25
(1,761 Views)
I forgot the vi, I see now.
I send it after lunch.
Message 18 of 25
(1,755 Views)
Only do not stop twice, there I made a small mistake probably.
Message 19 of 25
(1,748 Views)
Hi
After the test, the file format is as shown below.There is no occurrence of different data at the same time.
The file below is my test file.
Message 20 of 25
(1,731 Views)
