VMIC
I am using LabVIEW 2013 on a desktop PC and a LabVIEW RT 2013 in a PXI chassis. A GE VMIC 5565 which is placed on the PXI chassis is used to communicate via VMIC interface. I use VMIC both writing and reading data.
My problem is related with the reading data from VMIC interface. When I write a code which will write a 300 byte data in VMIC, the function is completed about 20-30 usec. However, when I want to read 300 byte from the VMIC, it is completed nearly 580 usec. Is it normal that there is a huge time difference between completion time of data read and writing vis?
(4,890 Views)
Read/write times can sometimes vary significantly depending on the protocol and hardware.  I believe the answer may be more directly answered by contacting there support:
http://defense.ge-ip.com/support/embeddedsupport/locator
(4,863 Views)
Thank you for your reply, I will contact with them.
(4,837 Views)
