where do I get BorlandC_gpib for ni4882.h?
Hi again!
I'm currently still trying to use ib-functions within a C++ program to control/read an electrometer.
I'm using C++ and everything is already set up, except the definitions for the ib-functions!
The declarations are in the ni4882.h-File, however, I can't find a valid "BorlandC_gpib-32.obj"-File.
I already found a sample-program, however it was fr ni488.h and ibsta(), iberr() and ibcnt() were still not defined with that one.
Does anybody know where I can get this file or the right one to ni4882.h?
I'm using C++-Builder XE2 for this.
Julian
(3,682 Views)
I found out, that ni488.h works with BorlandC_gpib.obj found in the NI-Software-Folder, given you installed an older version.
However, the newer ni4882.h needs a ni4882.obj, found also in this Folder from the new version:
C:\Program Files\National Instruments\Shared\ExternalCompilerSupport\C\lib32\borland
(3,669 Views)
Have you get the solutions? Recently, I want to control the GPIB interface withe the CBC6.0 and the XE4,.But it failed, I have added the ni4882.h and the ni4882.obj. also the decl-32.h and the gpib32.obj. but cpp file can not open the ni4882.h in the CBC6.0.
in the XE4, it is strange that
int deviceID=ibdev(0,LakeshoreAddress,0, T3s,1,0);
ibwrt (deviceID, "*idn?", 35);
it faield also and the input string "*idn?" cannot be passed
[bcc32 Error] .cpp(49): E2342 Type mismatch in parameter 'buf' (wanted 'void *', got 'const char *')
could you help me. thanks
(3,399 Views)
