VS2019 program viopen failed
In our daily work, we use visa library probvided by NIVISA.
Platform: windowsv
Our testing environment is: NI488.2 17.6 + NIVISA 2024 Q1
Currently we use VS2019 as our IDE tool, and in our implementation, we have dynamic link libraries as followed:
A.dll: Dealing with instrument communcation, using LoadLibrary to load visa32.dll/visa64.dll to deal with instrument communcation
B.dll: Control the whole flow, also depends on A.dll's API to talk to instrument indirectly
The problem is while I write a VS2019 app and just calling A.dll's API to communcate with instrument, it's OK.
But while I add B.dll into compilation, I still calling A.dll's API to communcate with instrument, but it failed
ERROR code is: (BFFF0011), Description: Insufficient location information or the device or resource is not present in the system.
Did anyone know any constraint in NIVISA's library, is this some kind of DLL hell?
(1,086 Views)
After some more investigation, here are some observation:
Background: Our library(Let's called it A.dll or A.lib) using LoadLibrary to load visa64.dll from IVI fundation
Environemnt: NI-VISA 2024Q1 + NI488.2 21.5
Experiment: VS2019 Application linking with A.dll or A.lib to test visa library fundamental API
  • Static link library A.lib: Success
  • Dynamic link library A.dll: failed in viopen , error code:BFFF0011 : Description: Insufficient location information or the device or resource is not present in the system.
Also found that using ListDll to check dynamic link library dependency:
Its weird that dependency are different between static link and dynamic link library version:
Static library A.lib: Dynamic link library A.dll
C:\windows\SysWOW64\visa32.dll C:\windows\SysWOW64\visa32.dll
C:\windows\SysWOW64\NiViSv32.dll C:\windows\SysWOW64\NiViSv32.dll
C:\windows\SysWOW64\secur32.dll C:\windows\SysWOW64\secur32.dll
C:\windows\SysWOW64\SSPICLI.DLL C:\windows\SysWOW64\SSPICLI.DLL
C:\windows\SysWOW64\NiSpyLog.dll C:\windows\SysWOW64\NiSpyLog.dll
C:\Program Files (x86)\IVI Foundation\VISA\WinNT\Bin\NiVi488.dll C:\Program Files (x86)\IVI Foundation\VISA\WinNT\Bin\NiVi488.dll
C:\Program Files (x86)\IVI Foundation\VISA\WinNT\Bin\NiViAsrl.dll C:\Program Files (x86)\IVI Foundation\VISA\WinNT\Bin\NiViAsrl.dll
C:\Program Files (x86)\IVI Foundation\VISA\WinNT\Bin\NiViEnet.dll C:\Program Files (x86)\IVI Foundation\VISA\WinNT\Bin\NiViEnet.dll
C:\windows\SysWOW64\WININET.dll C:\windows\SysWOW64\WSOCK32.dll
C:\windows\SysWOW64\WSOCK32.dll C:\windows\SysWOW64\WININET.dll
C:\Program Files (x86)\IVI Foundation\VISA\WinNT\Bin\NiViEnetAsrl.dll C:\Program Files (x86)\IVI Foundation\VISA\WinNT\Bin\NiViEnetAsrl.dll
C:\Program Files (x86)\IVI Foundation\VISA\WinNT\Bin\NiViPxi.dll C:\Program Files (x86)\IVI Foundation\VISA\WinNT\Bin\NiViPxi.dll
C:\windows\SysWOW64\niqpxi.dll C:\windows\SysWOW64\niqpxi.dll
C:\Program Files (x86)\IVI Foundation\VISA\WinNT\Bin\NiViRpc.dll C:\Program Files (x86)\IVI Foundation\VISA\WinNT\Bin\NiViRpc.dll
C:\windows\SysWOW64\nirpc.dll C:\windows\SysWOW64\nirpc.dll
C:\Program Files (x86)\IVI Foundation\VISA\WinNT\Bin\NiViUsb.dll C:\Program Files (x86)\IVI Foundation\VISA\WinNT\Bin\NiViUsb.dll
C:\windows\SysWOW64\kernel.appcore.dll C:\windows\SysWOW64\kernel.appcore.dll
C:\windows\SysWOW64\uxtheme.dll C:\windows\SysWOW64\uxtheme.dll
C:\windows\SysWOW64\winimhc3.dll C:\windows\SysWOW64\winimhc3.dll
C:\windows\SysWOW64\comdlg32.dll C:\windows\SysWOW64\comdlg32.dll
C:\windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_5.82.19041.844_none_89e26e970b35ab92\COMCTL32.dll C:\windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_5.82.19041.844_none_89e26e970b35ab92\COMCTL32.dll
C:\windows\SysWOW64\thooksv3.dll C:\windows\SysWOW64\thooksv3.dll
C:\windows\SysWOW64\iphlpapi.dll C:\windows\SysWOW64\iphlpapi.dll
C:\windows\SysWOW64\NSI.dll C:\windows\SysWOW64\NSI.dll
C:\windows\SysWOW64\dhcpcsvc.DLL C:\windows\SysWOW64\dhcpcsvc.DLL
C:\windows\SysWOW64\MSCTF.dll C:\windows\SysWOW64\napinsp.dll
  C:\windows\SysWOW64\pnrpnsp.dll
  C:\windows\SysWOW64\wshbth.dll
  C:\windows\SysWOW64\NLAapi.dll
  C:\windows\SysWOW64\DNSAPI.dll
  C:\windows\SysWOW64\winrnr.dll
  C:\Windows\SysWOW64\rasadhlp.dll
Can anyone explain what make this difference in NI-VISA viopen implementaion?
It seems like the function go into different ways in C:\windows\SysWOW64\NiViSv32.dll.
(998 Views)
